4.3 Coolant Block plug?????
jcblizz
I have a problem hooked my boat up the the muffs the first time this year and it fired right up. but the round plug that goes in the block under the motor mount popped out and water just rushes out. What can i do? is it just pressed in? Thanks!
Bt Doctur
Re: 4.3 Coolant Block plug?????
They are just pressd/driven in with a suitable tool .BUT, they only pop out from freeze damage. Any water in the oil yet??
jcblizz
not yet still slick and clear. this was the first time out of the garage
Don S
There probably won't be any water in the oil with the "CORE Plug" missing. Once you get a new plug in it, run it for a while and see if your oil level starts rising and the oil turns milky.
jcblizz
will do gonna take a day or two. i have to take the motor mount out of the way.
ElCameeeno
A rubber expandable plug is easy to put it and works for a temporary fix.
jcblizz
ok well it was a chore but i got the plug back in. hooked it up to the muffs and let it warm up to around 200 till the thermostat opened and brought it back down to around 160-180. checked the oil. still slick and clear. seems ok.
Gary H NC
Keep a close eye on the oil after you run it under load on the water.
You may have dodged a huge bullet!
Next year drain the block and manifolds before winter storage.They can freeze in the garage unless you have constant heat in there.
jcblizz
well im guessing i am the luckiest person alive right now. ran the boat for about 4 weekends. just changed the oil and no water just a lil dirty.
