Murrayhardcash
Thread starter- Joined
- May 11, 2010
- 2
I have a 4.3 and the starboard riser is noticably warmer(hot) than the port side. They're new manifolds , I took off the thermostat housing to inspect , it was pretty clear, although running water into to the feed inlet with the larger hose nipple blocked and with the larger thermostat opening blocked I did see a different flow port and starboard output (therm housing).
During operation in water the hose's wind up having two different temps.
QUESTION is it normal for the starboard side to run hotter ?? the engine apears to be the same temp both sides , to feel . Murray
