4.3 cruiser rough running
Clarko1988
87 4.3 merc back fires through carb at 8 btdc and runs great at 12btdc also when i turn the engine off i can hear air sucking threw motor. I am stumped.
achris
More fish than mountain goat
Check that the zero degree point is actually at zero degrees.
Clarko1988
Motor runs smooth other then when give it gas it back fires although when i rebuilt carb the kit came with a longer accelerator pump plunger could that have anything to do with it
QBhoy
I am sure you'll know already...but make sure its 100% fresh fuel you're giving her. Bad fuel will result in exactly the described too.
Ayuh,..... The backfire says it's goin' Lean,.....
