were can i get a 153 tooth flywheel to fit 1990 4.3 leg volvo 290 ???? help please:confused:
WHATEVER??? Cadet Joined Aug 11, 2008 Messages 16 Jun 25, 2010 #1 were can i get a 153 tooth flywheel to fit 1990 4.3 leg volvo 290 ???? help please
4Winns2 Petty Officer 1st Class Joined Nov 2, 2006 Messages 327 Jun 25, 2010 #2 Re: 4.3 flywheel The 4.3 is a Chevy block that was used primarily in the S-10 pickups. There are a lot of those engines out there. I would call some junkyards to save some money.
zbnutcase Commander Joined Sep 19, 2009 Messages 2,055 Jun 25, 2010 #3 Re: 4.3 flywheel Except all the truck engines used the 168 tooth flywheel!
WHATEVER??? Cadet Joined Aug 11, 2008 Messages 16 Jun 25, 2010 #4 Re: 4.3 flywheel all i can find is 168 tooth witch is to big to fit in the bellhousing
zbnutcase Commander Joined Sep 19, 2009 Messages 2,055 Jun 25, 2010 #5 Re: 4.3 flywheel Call KEM Equipment in Tualatin, Oregon. They should be able to hook you up.
WHATEVER??? Cadet Joined Aug 11, 2008 Messages 16 Jun 25, 2010 #6 Re: 4.3 flywheel still cant find 1 dont mind geting a new 1 but cant find 1
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,084 Jun 25, 2010 #7 Re: 4.3 flywheel WHATEVER??? said: were can i get a 153 tooth flywheel to fit 1990 4.3 leg volvo 290 ???? help please Click to expand... Ayuh,... What's the matter with the 1 you have,..??
WHATEVER??? Cadet Joined Aug 11, 2008 Messages 16 Jun 28, 2010 #8 Re: 4.3 flywheel the flywheel i have is off an older 4.3 ie 2 piece rearmain seal the new 4.3 is a 1 piece rear main seal and the crank bolts r diffrent help
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,084 Jun 28, 2010 #9 Re: 4.3 flywheel Ayuh,.... Donno,... Big flywheels are what Merc uses... I found this on a quick google,... "Flywheels and Bellhousings The 4.3 V6 is typically found with a 168 tooth flywheel (11" clutch disc) behind it instead of the more-common 153 tooth (10.5" clutch disc). This is done for clutch engagement, but moreso for the weight and resulting torque provided. Therefore, the V6 requires the "big clutch" bellhousing which affords greater clearance. As the V6 has the same crank flange as the V8's, total caution should be taken when swapping flywheels around from the V8 to the V6. We're told (this is hearsay, folks) that the 153 tooth flywheel from the 305 V8 will bolt up and be properly balanced." Good Luck...
