Lou C
- Joined
- Nov 10, 2002
- 13,821
A couple of your plugs look so lean it’s as if they were never used; I think that carb needs to be gone thru and cleaned out. And those V/P timing specs don’t really make sense to me, that spec seems to have the level of advance jumping up very early. I looked at the chart for my old ‘88 pre Vortec 4.3 with the 4bbl and points Prestolite distributor. It starts with 6* base timing at idle, @ 1500 its at 12* total @ 2500 its at 16* total, and it peaks @ 3200 with 18* total. Are those specs from iBoats or right from a VP factory shop manual? I can imagine that if you have Vortec heads you might be able to run at more advance but that seems like a big difference.
as an example I was looking around to see what specs I could find on Merc rigged 4.3s and found this;
https://www.mtboats.com/mercuryignitionadvancemodules.html
look at the top one for the V6, 14* of advance, so if you start with a base of 6* which is typical on the 4.3s you wind up with a total of 20*
now if your engine ran well with no popping for a while and then this started the question is what changed?
couple of possibilities:
intake valves not sealing well
intake gasket leak
carb gasket leak
defective distributor cap
I would for sure do a compression test and leak down if possible
keep in mind that exhaust system problems (leaky manifold to elbow gasket) can cause corrosion on valve stems and seats due to water intrusion....
intake gasket leak
carb gasket leak
