Re: 4.3 L carb question
Even though it is new does not mean it is jetted correctly. Eldebroks out of the box 600 cfm carb has a kit that needs to be installed to rejet and new needles...If i remeber right WCA Trim went thourgh a few jets to get where he wanted to be..Perhaps wh will chime in. I am not sure of your experience but a 95 4.3 was about a 170 hp motor and 600 cfm is a huge carb. You indicate your power is up @ wot where the engine gets a maxium air to fuel ratio which would help lean it out.
A 280 hp 4.3 uses a 600 cfm carb..good luck
Ahh the search function....I seriously doubt there can be a question that cant be answered with that funtion...
http://forums.iboats.com/showthread.php?t=50261&highlight=4.3+jetting
The Mercruiser 4.3 LX Weber settings
rimary Jet = 0.089Secondary Jet = 0.089Metering Rod = 16-6857 (68 x 57)Metering Rod Spring = YellowIf they are part of the kit, all the better.
There ya go...Call holley with those jet setting.....tell them what you have and i am sure they will recomend something
