Captianloud
Thread starter- Joined
- Jan 16, 2006
- 43
Hello new to the forum, I search for this but didnt find any results. <br />1994 Mercruiser 4.3 L V-6. What makes this short block different from the automotive 4.3L short block. Will it bolt up?<br />I bought a 94 Bayliner w/ a 4.3 knowing the engine was run while low on oil, he lost oil pressure. I have not ripped into this yet. But I would rather just replace the short block than rebuild the bottom end. All other marine components are functioning, intact and reusable. <br />I know the cams are different. Crankshaft is the same. But are the blocks the same? Will it bolt in. I am fully capable of making slight modifications. I understand the importance of using marine gaskets and seals, as well as using the other marine components. I can drill and tap holes to relocate drain/freeze plugs. Remember that I have the complete old engine to use as a template, and/or for parts, brackets, and other miscellaneous salvage. I dont want to spend $1100 for the short block when I can pull the engine out of an Astrovan or S10 at the local u pull it yard for $50. <br />There has to be a fellow gearhead out there that knows. <br />Any advice would be GREATLY appreciated. <br />Thanks in Advance!,Capt...
