hi bug up, i'm very new to mercruisers myself, but i think i read somewhere that the electric fuel pump operates when there is oil pressures, i'm not 100% sure as i have a mechanical pump! A sure way could be to check when the fuel pump actually operates with a voltmeter across it. As well as this you could try checking for fuel delivery to the carb by disconnecting the inlet pipe, but i cannot emphasise enough that you must find a method of doing this safely, grounding the h't lead to make sure theres not gonna be any sparks , and collecting pumped fuel into a connected pipe away from the engine. As for when it starts, could it be the angle the boat sits in the water? Good luck bob
bugup said:I am having a hard time starting my 4.3LX. It will start fine in the driveway or when I first launch at the boat launch, however my problems have been after it has been in the lake over night. I know this sounds wierd but every morning or after it has sat for 5 hours or in the water the following happens: I pump it once and it starts and runs for about 20 - 30 seconds and then dies. I then removed the flame arrestor and asked my buddy to pump the throttle and I can't see any fuel being shot in. After this the only way I can get it to start is by putting a little gas or ether down the carb and then it will fire. After it starts I then have to hold the revs at 1500 until I get some temp and then I can bring it back to idle.
Some questions I have are :
1. Any idea of what is happening because it is getting a little embarassing at the camp site?
2. When I turn the key on should I be able to hear the electric fuel pump? I hear nothing and I am curious if this is why I can't get fuel when I try to prime it.
Please help. Thanks
