Scott06
- Joined
- Apr 20, 2014
- 7,562
You will not get any power to fuel pump if engine is not running and ignition is on unless you jump out the oil pressure switch. The purple yellow from starter is what supplies power during cranking. If you think is fuel related dump some gas down carb and crank it over.if you have ignition it will at least cough and run a bit.However, when I use a spark tester, i get a steady blue spark. I started testing some of the wires and tracing them, and I’m not getting any power on the purple wire at the plug to the fuel pump.
since you have spark on gap tester are you sure rotor is getting spark from cap? Sounds like yiu might be loosing spark inside dist
