4.3 Mercruiser Hard Starting when cold, Starts fine once warm
synergy141
Having trouble starting my 4.3 Mercruiser LX, its a 1994. Before I start I pump the throttle a few times in neutral. It will fire up for a second then shut off. What can the problem be?
Bt Doctur
Re: 4.3 Mercruiser Hard Starting when cold, Starts fine once warm
choke not adjusted? instead of coming back to neutral, leave it slightly advanced.
synergy141
I pump it and then leave it 1/4 throttle, it still dies, then once it turns over I pump it hard and it still dies 1 second after.
dubs283
make sure the choke is closed after the initial throttle pump before starting the engine cold
pumping the throttle will give a nice blast of fuel from the accelerator pump well but only about 1 oz. of fuel
when cranking the fuel pump will refill the well and you get that nice blast from the accelerator pump but again, only about 1 oz.
check the choke
synergy141
is the choke the one metal flap on the front of the carb or the 2 metal flaps at the back of the carb? . Im guessing its just the one at the front. that one stays closed but will open up a little if I put the throttle to WOT
Alpheus
What kind of carb do you have?
synergy141
its the 4.3 LX so it should have a 4 barrel Weber
synergy141
i tryed to bypass the oil pressure sensor like other people have done, but again the engine would fire up for a second and die.
dubs283
the oil pressure sender/switch has nothing to do with the choke operation
the reason it didn't run when you disconnected it is because the fuel pump voltage is received from that circuit
synergy141
so you think the choke is the problem? What can I troubleshoot next?
tractoman
The choke, it should be mostly closed when cold and it is set. Once the engine warms up it will gradually open. If you can't find the merc manual for that Weber, go on the Weber site or Edelbrock site and you should be be able to find instructions to check the choke adjustments. They are virtually the same. On mine, I pump the throttle a couple times, leave it at about 1/8 throttle and turn it over. If it's cold it takes a couple tries, but I don't crank it for 2 minutes. I crank about 5-7 seconds and repeat. It usually fires up after a couple tries. When its warm, no throttle and it fires in a couple revolutions.
synergy141
The choke is closed when it is cold with just a little bit of gap for air. So I think the choke may be working. maybe not?
dubs283
if the choke plate is closed with the throttle at idle, it is set properly for starting
with the engine off and cold (not been run for a day at least), remove the throttle cable from the carb and manually open the choke plate
fully pump the throttle arm on the carb, you should see two definite streams of fuel being directed down the barrels of the carb
if not, there is a fuel delivery issue or a carb leak issue
synergy141
earlier today when the engine was cold I did pump the throttle. ( but without removing the cable like you mentioned) I had a friend look into the carb and he could see 2 fuel streams being shot into the carb bowls
dubs283
the streams should be definite, like a squirt gun (best analogy) and you should be able to pump multiple times and see good streams with each pump
i would say, 3 pumps - should see 3 good fuel squirts - after that, there would be no fuel left in the accel pump well
synergy141
Im not sure i they were big streams, I would have to see for myself. If they are weak streams what could that be? blocked passages?
synergy141
maybe if I changed the fuel/water seperator that may help
Alpheus
That your accelerator pump is going bad, floats are set wrong and not allowing the bowls to fill up completely,check ball sticking.
You may be have a leak inside your carb and flooding your engine(fouling your spark plugs) causing you to have to crank the heck out of it to get it to start. Again this could be a heavy or a un-adjusted float or bad needle and seat.
To diagnose this, prop open the choke and try your normal start up procedure when cold...
