tgjohnson1
Thread starter- Joined
- Feb 21, 2010
- 18
Hello everyone. I'm back with a different boat and more problems. I have a 97 gm 4.3 with a Alpha 1 drive. There is oil in the bilge after i run the boat. The boat just came back from the shop after having the out drive gone through and new gimble bearing replaced as well as other part in the outdrive. There is a spot that i have found on the front of the motor between the head and intake that looks wet. Is this where its coming from? The other problem is that it will not go above 3500 RPM and 28 MPH and bogging when taking off. Do these both come from the same problem? The boat is a 20ft Bayliner with a 21 P prop. Can someone help me please.
