4.3 Mercruiser Prop Questions
blorr
I'm a newbie boat owner and have some questions.
I have a 4.3 Mercruiser with a Alpha One outdrive on a 18ft. Dynasty boat motor and boat are 1993.
Here are my questions:
What should be my top speed? I'm only getting up to 37mph with one person in the boat with it trimmed up. That seems slow.
What is the best prop? Currently I have a Solas 15 X 19 stainless 3 blade. We do ski alot behind it. Is this the best size and pitch?
Right now my max RPM's are barely getting to 4000 with it trimmed up. Is this too low? Does it matter?
I really appreciate your help. Some of these might be dumb questions, if so I apologize.
Thanks for the replies!
Brent
Don S
Re: 4.3 Mercruiser Questions
Since about 90% of this post is about speed and prop, I am going to move this over to the prop forum.
Sometimes the boat just dies while running at WOT. It takes about 10 minutes to get it started back. Is this a fuel pump issue?
I would suggest you post the above quote as a seperate question in the IO forum.
Asking to many different questions in one post is going to be real hard to follow, and will get you fewer answers.
hwsiii
Re: 4.3 Mercruiser Prop Questions
Blorr, you should be able to get 4,800 RPM out of that motor and since you are only getting 4,000 RPM you need to first check and see if you have a motor problem, which it appears you do from the other statement you made. After you have your motor right come back and I will be glad to help you find the right prop. We want to make sure that we don't change props and the find out you had the right prop all along but the motor problem caused the loss of RPM.
H
blorr
Sounds good. Thanks!
Brent
hwsiii
You are very welcome Brent.
H
blorr
Let me ask this though.
What should be the typical top end speed at WOT for a 4.3 Mercruiser with a 18 ft boat?
Thanks,
Brent
sikz3
I'm getting 45 mph (speedo, not gps)@ 4200 with one on board w/ my 18' powered by a 4.3l mercruiser, got more throttle to give but never gave her full hrottle (nervous) bought her less than two months ago and kinda scared to redline her. I have a 14 1/2 x 19p @ 4000' elevation
nlain
My 04 185 SeaRay, 4.3, Alpha, 14X23 stock prop, with 2 over 200 lb adults, gear for the day, bimini up, 49 GPS, 5200 rpm if tach is right, do not here rev limiter kick in. Max rpm should be 4800. My boat is listed at 2650 lbs dry weight, so loaded I'm a little over 3000 lbs. So once you get your engine checked and right somewhere in the 4800 rpm range and at least mid 40's I would think for your boat, if it is heavier than mine then that will possibly change that a little. Good luck, lets hope just a good tune up or maybe carb rebuild is what you need.
truckermatt
18.5 foot wellcraft... 44 mph on GPS (47 on speedo) Trimmed up, 2 people full tank of gas. 14.25x21p 3 blade
blorr
Ok, here is what I got.
Had a 15X19 stainless prop and got 4100 RPM at WOT and top speed of 37
Put a 15 3/4 X 15 Stainless mirage plus prop and got 4800 RPM at WOT and top speed of 39.
Definitly liked the second one better because the hole shot was awesome.
This is all with just one person in the boat.
Should I try anything else or is this about what I can expect?
Ayuh,... It sounds like your motor is seriously Down on Power,...
Maybe a Tune Up,+ compression test is in order...
