1995 4.3 Mercruiser, 2bbl carb. Runs great when engine is first started cold and after 10 minutes begins to lose power and will get worse as engine warms up. Here are the parts we know are good, or are at least new: Ignition coil, Ignition module, spark plugs, plug wires, distributor pick-up coil. Ignition timing is at 8 degrees BTDC, Dist. cap and rotor fairly new with no visible cracks, choke is working properly, fuel pressure 6 -8 psi., fuel volume - 1 pint in 15 seconds. Fuel filter clean and water seperator new. Fuel tank emptied for cleaning within last year. Oil pressure correct and oil level correct. Oil pressure switch for electric fuel pump by-passed for testing purposes (so fuel pump does not shut-off due to any potential oil pressure concerns). The carburetor float bowl is clean and float level appears correct.
Again, this boat runs absolutely great when first started and driven.
Please give any thoughts on the cause, I am stumped for now.
