Thought I would post a few pics of my most recent problem with the boat I recently purchased. The outside starter mount broke off and the previous owner just epoxied it. Not sure how long it has ran like this, but it failed on my last trip out. When it happened I found a few post of the same thing happening to other people but not much on repair.
To start I turned down a piece of aluminum to fit. A 3/8 - 16 bolt, so I could align the piece that broke off to the threads left on the block. Aluminum, to help hold the broken off piece in place and so I could leave it in and wouldn't have to worry about the aluminum bonding to the cast. I took a couple of different sized burr bits to clean everything up and try to groove it out without touching the threads. I tigged it using 309 3/32 wire running about 75 amps. Welding very little at a time, maybe 3/4" tops and letting it completely cool before resuming. Anyway here are some pics of the repair this far.I may make up a support bracket to help support the back end. Hopefully this post will help someone. I will add more photos when this is complete.
