4.3 Mercruiser Thunderbolt IV base timing
Merc4ever
Most of us know the Thunderbolt V has a purple wire that needs to be grounded to set the timing in order to stop the auto advance. But what about the Thunderbolt IV on a 4.3 Mercruiser? I'm trying to time it right now and can't find how to put it into base timing mode. The Mercruiser Service Manual doesn't mention it in the timing section and I know there is no purple wire to ground on the Thunderbolt IV.
Don S
Re: 4.3 Mercruiser Thunderbolt IV base timing
The Thunderbolt IV system does not get put into base timing mode.
Ayuh,.... The T-Bolt IV is simply attach the timing light, point,+ set....
Merc4ever
Duh... I just spent 2 days lookin for the damn thing! I should have just visited iboats first. My manual covers several years but doesn't specify the Thunderbolt IV doesn't have the wire.
Merc4ever
Once again, Thank you all very much!
Don S
That is because when the TBolt IV system was used, there was no such thing as TBolt V and putting things into base timing. So why would they specifically say not to put in base timing mode ???????
________________________________________________________________________
:D:D Ayuh,...:D:D
