I seen this posted in the past forum but it didn't quite answer my question. I have a 03 Fourwinns with a 4.3 mercruiser (thunderbolt ignition). I'm looking at timing the engine; however I cannot find the timing tab. I see the one line on the balancer but no "tab" on the engine. I could have sworn I've seen one there before (a tab). The only thing I see is a chuck of metal (looks like it's cast in) with a V cut into it, but no tab with different lines (or degrees) on it. Could the tab have fallen off? If so, is there something I can do to correctly time the engine. I attached some pictures.
Also the purple/white wire in the picture? is that the wire used to put it into base timing mode? The black ?spade? terminal next to it? could I use that as a ground to hook up the purple/white wire to.
I attached 4 pictures. One shows the general engine (for identification purposes), another one shows the wires in question, the third one shows what I think is the timing mark on the balancer (just making sure it is), the last shows the ?tab?.
Just a side note... I have never timed an engine before but understand the concept. I'm pretty mechanically inclined as I've rebuilt automotive engines and transmissions so I'm pretty sure I can tackle the whole timing thing.
I do own the mercury factory service manual for that engine.
Thank You.
Thank You.
