Wyomingman
Thread starter- Joined
- Mar 26, 2009
- 38
I have a 4.3 Mercrusier with the single point drain. I drained the water and also removed the two blue plugs, one from the thermostat housing and the other below by the drain.
Now the question. I removed the thermostat housing a poured anti-freeze down through the block and watched it drain out the bottom through the drain and it was pink anti freeze coming out. i don't want to store it with anti freeze, but can i now be sure all the water is out since the pink anti freeze is coming out the drain?
