4.3 Mercuiser Hard Strating when Warm
easyloader
The motor starts perfectly when cold, if idling on muffs for twenty minute boat still starts fine. If running it hard for a few minutes the motor cranks real slow then starts up. I have a mp4 but can't attach it.
Any ideas.
dubs283
Re: 4.3 Mercuiser Hard Strating when Warm
would need to connect scan tool and monitor data items/check for faults
when was the last full tune-up??
easyloader
I've replaced exhaust manifolds/risers/flappers due water infiltration.
while I was at replaced cap rotor,wires and plugs.
Someone mentioned it could be timing, hydro lock even though oil has no water, or bad compression.
am calling mechanic tomorrow.
what do you think?
dubs283
i think a reputable marine mechanic will find the issue
did you check/adjust the timing after the new plugs, cap/rotor, etc...???
hydrolock will not show water in oil, but is possible with a faulty exhaust manifold(s)/gasket(s)
stang32
check the timing ,also check to make sure the battery connections are tight, if the engine is hot & there is any voltage drop, the engine will crank slow, stop crank,start
easyloader
The mechanic came by today and check the timing which was way off. I'll test it in the water this weekend.
My only concern is the way the mechanic adjusted the timing. All he did was put the timing light on number 1 cyclinder and made the adjustment. Based on forums I've read I thought that you had to put the ECM module in the service mode before adjusting the timing?
dubs283
probably, what is the enigne serial number??
dubs283
if it has the thunderbolt 5, you must ground the purple/wht lead when checking/setting timing
thunderbolt 4 is adjusted like a conventional ignition
CaptainMak
This mechanic is reputable, right ?! Knows his stuff ?
