vernonbluewater
Thread starter- Joined
- Jun 16, 2010
- 13
Cruising @ 30 mph ran at 175 degrees. Apparently should be 160. Has aftermarket closed cooling system with heat exchanger . Exhaust risers still raw water cooled. When slowing down from cruise to 5 mph alarm would come on - a touch of throttle would turn alarm off.Replaced impeller, (looked fine no wear) replaced thermostat to 140 degrees ( turns out already had 140 in it, replaced anyways )- now runs hot on hose , 200 degreees instead of 175 before. I made it worse. Any suggestions would be appreciated. Really wondering why I bought a boat, nothing but aggravation. Thought I would be enjoying with family instead of fixing ALL the time. Boat mechanic says could be exhaust risers clogged. Oh yeah, I checked heat exchanger clean & clear.1993 4.3 mercruiser 4bbl . Question - if running on hose, how does impeller suck in water if not in drive?
