4.3 motor swap with truck engine
timharper89
I'm planning on swapping my knocking 1987 4.3L merc (s/n 0B459735) engine with a truck donor. Everything I've found is late 90s and later (vortec). What accessories can I keep from my old motor, and what won't fit? I know the intake manifold is different, but is there anything else?
As far as checking the new motor, compression test, take off the valve covers...anything else? I know I need an alignment tool. Any other non standard tools I might need? Any other advice here? I have next week off and am hoping to get it swapped out then. Thanks for any help
itsathepete
You can use your 1987 cylinder heads and intake with the donor if you like but you will get a significant power increase from the vortec heads. They will require a new intake manifold. Make sure you get one that fits your carb, be it 2 or 4 barrel spreadbore or squarebore. If you are going to be in saltwater you must get a marine intake. 99% chance there will not be a way to mount a mechanical fuel pump on the donor engine so you will have to convert to an electric fuel pump. Get a good name brand (Carter and Airtex are a couple) marine low pressure electric fuel pump. Also a fuel pressure regulator and an oil pressure cutoff switch and associated wiring supplies.
You will strip everything off the donor engine until it is just a block and heads. You will use all the accessories from the 1987 engine to put on the new engine. You may need to use the timing cover off the old engine if the balancer has a different seal size. Get an engine gasket kit, head bolts and silicone sealant. Get a set of brass core plugs and replace the automotive steel ones. It's a good idea to replace the rear main seal and oil pump while you're there.
achris
More fish than mountain goat
Just be aware that later 4.3 blocks may have some metric fastener threads, so you might need to replace bolts (things like starter motor bolts)...
Your 1987 is a 2bbl without a balance shaft, so the water pump may not fit. (too close to the block for the wider timing cover.)
Chris......
remember, you have to take the vortec motor or any truck motor, knock out the core plugs and replace them with brass or stainless
you also need to use marine head gaskets
the only thing you need from the truck is the block and heads unless you get a motor from a truck with a manual, then the flywheel too
you will not be using any of the accessories, brackets, pulleys, water pump, etc from the truck.
vortec marine intake manifolds can be gotten used, or new for about $300
I would upgrade to a PMGR starter
@nola mike did a mix and match of vortec and non-vortec in his thread
itsathepete
Chris......
If the water pump doesn't fit because of the timing cover, the timing cover from the old engine can probably be used. It will be metal, and not stick out as far.
Scott06
The bolts that are metric are side motor mounts, flywheel cover mounts, starter bolts. Metric is an M10 thread, US is 3/8-16.
Ironically on a metric block all other threads are US , not sure why GM did mix and match on same block. When I swapped my metric 4.3 for a 5.0 ended up costing about $40 for the bolts including the proper starter bolts.
timharper89
I think I'll start with what I have and make sure I can get it running before doing that. If I go vortec later I'll get a new 4bbl marine carb as well.
If in freshwater only I don't need specific marine intake?
Already have all this due to a fun project the previous owner left me with when I bought it. There is no mechanical fuel pump hole on my block.
Thanks for this
timharper89
Why the flywheel if it's a manual?
I read something about maybe the belt would be different on newer motors. Is this anything to worry about?
What's the benefit of this?
timharper89
Chris......
Can I just use the bolts from the donor?
timharper89
Can I just use the bolts from the donor motor?
itsathepete
Just use the intake you have if keeping old heads
automatic trans uses a flexplate, manual uses flywheel, marine uses flywheel
You will be using all your pulleys and accessories so, no.
achris
Freshwater is still corrosive. And an aluminium manifold bolted to iron heads forms a galvanic cell... The only time you don't need a marine intake is if you're running coolant (cars and close cooled marine).
? You have a Gen II block? If so that means it has a balance shaft, so the timing cover and water pump WILL go over to the new block.
The belts only drive 'accessories', and since you'll be using all the accessories from the old engine you can use the belt system you currently have.
Most likely yes.
nola mike
This confused TF out of me when I started stripping out the holes using nearly identical to M10 ⅜ bolts. Ridiculous.
Vortec heads are an honest 20hp because of the chamber shape. Used iron vortec manifolds are $50 or less
PMGR starter is 22# lighter than a direct drive starter, uses half the power and has twice the torque
You use nothing bolted to the truck block and heads. You have to use the marine stuff from your current motor
If you do not have a mechanical fuel pump boss, you may already have a vortec block in the boat. Post casting numbers
How many bolts holding the intake on the busted block? 8 or 12?
