4.3 rebuild ?'s
Cpt D
Re: 4.3 rebuild ?'s
I cannot believe there's people trying to argue with Bondo!!! Follow Bondo's advice and you won't go wrong!!! (The truck cams are the same as marine)
Doug
ssleeper94
Re: 4.3 rebuild ?'s
well then I'll just leave the cam the same, means more money for gas and beer.
thanks for the help.
ssleeper94
Re: 4.3 rebuild ?'s
One last question, I was reading in another post about putting vortec heads on, I have a line on a set out of a 1995 blazer for $50, my question is for the time being will the current 2brl intake manifold bolt up to the vortec heads because the motor the heads are on doesn't have a carb manifold
Re: 4.3 rebuild ?'s
Ayuh,... Unless the 2bbl. manifold is Also a Vortec manifold, No...
The manifold to heads interface is Very Different...
180shabah
Re: 4.3 rebuild ?'s
STOP!
The "vortec" heads were not intro duced until '96, so they were not on a '95 blazer.
However, GM has been using the TERM vortec since '87 when the TBI heads came out. That '95 blazer will have the same heads I am currently running with 6 intake manifold bolts per side and composite valve covers that SAY vortec, but they are not the vortec heads that people actually want. The heads you want will only have 4 IM bolts per side.
ssleeper94
Re: 4.3 rebuild ?'s
STOP!
thank you, the guy advertised them as 95 vortec heads.
ssleeper94
Re: 4.3 rebuild ?'s
I found a set of vortec heads complete w/ pushrods and lifters 3000miles on them edelbrock 600cfm 4barrel and edelbrock intake for 300-350...is that a fair price?
180shabah
Re: 4.3 rebuild ?'s
Maybe????
Are we sure about the heads being true vortecs?
What is the PN on the manifold? 2111 you don't want any part of this deal, 2114 = vortec.
Assuming that 4bbl is an automotive carb, you CAN'T use it. Is seller willing to break up the set?
ssleeper94
Re: 4.3 rebuild ?'s
the intake is a 4 bolt per side, i thought that was the tell tale well of telling if its post 96 vortec
ssleeper94
Re: 4.3 rebuild ?'s
Good to go, what about the carb?
carb turned out not being a marine carb just a edelbrock 600, the guy is offering me a cam w/ it but I dont know if its worth it or too big
intake exhaust
474 483
250 288
108 lobe separation
180shabah
Re: 4.3 rebuild ?'s
LSA is too close.
I'd keep the blazer cam that's already installed.
