4.3 vortec head and 4 brrrel swap
rookie1567
i have a 1992 bayliner 2050 with a 4.3 2 barrel novortec heads can i put vortec heads on it with a 4 barrel and can i use the same distributor
Re: 4.3 vortec head and 4 brrrel swap
Ayuh,... The Heads, manifold,+ valve train are what's Swapped for that...
The Distributer don't care...
zbnutcase
Yes and make SURE you use a MARINE carb and type A1 fuel hose! 'nutcase
180shabah
Big time power from that "little" engine, it'll make you smile.
rookie1567
put will the distributor work with vortec iintake
superpop
It is the best bang for the buck upgrade you can do. I think it is good for around 40HP if you do both. I had a 1996 Wellcraft with the 4.3L Vortec motor with a Holley 4V and it was pretty quick. With a 21P prop it would do 48MPH with a light load, and my Wellcraft was a heavy boat, about the same size as yours though. I have heard that the plain cast iron intake works just fine, or if you are not in salt, you could get a nice aluminum intake. Have you checked compression in the motor lately. If it is low, now would be the time to swap it all out if the motor is tired.
