ericp501
Thread starter- Joined
- May 14, 2011
- 149
Boat started 2 months ago then sat. I put on a new fuel/water filter on (filled it with gas and hooked an electronic gas pump between tank and filter to push gas through) still wouldn't start. The engine turns about 1 time then there is a loud grinding and stops spinning, sometimes the belts even kick back. So I put in a new starter, same thing. I tried putting 2 fully charged batts on to start it and still same thing. I tried turning the crank to make sure the flywheel isn't missing teeth and I looked at it when I pulled the starter, looks ok. So I'm really looking for ideas as I need to get this thing winterized asap. One other note, as I spin the crank with a wrench I can hear what almost sounds like air leaking from somewhere.
Boats a 96 welcraft with a 4.3 mercruiser I/O
