Saline Marina
- Joined
- Sep 9, 2014
- 162
Hi All
I managed to kill my motor over the winter, not sure exactly what I did wrong, all brass plugs were out, all the holes rodded out to promote waterflow. First trip out this spring I assumed all is well and was out on the first lake trip when I opened the engine cover to find the entire engine coated in MilkShake. Idled back to shore with no more output from the PCV tube but I'm certain the oil side and water side of the engine are compromised. Interesting I could not tell any difference in the operation of the motor but I feel certain I would have spun a bearing at some point.
I'm in the process of pulling the drive and pulling the motor, seems like its worth a basic water-side pressure test with the oil pan off just to confirm, once the motor is on the stand.
But I'm 99% sure that a longblock is required. My gut tells me to get a 99 or 00 reman 4.3 longblock for an S-10 pickup truck, pull the galvanized freeze plugs and install brass, then switch all the covers and dress over. I've swapped motors in trucks twice following most of above with 100k success both times, so I feel like I have the skill to do that part of the job.
Wanted to solicit feedback on whether my engine sourcing plan will work and if the standard "reman 4.3 truck engine" (with warranty) is going to be proper. I feel certain I will have more questions as I go but wanted to get this part moving. We have a family lake trip in 1 month, so now I have reality TV drama to go with it....
Thanks!
(edit, this is in a Four Winns 170 if it matters)
Thanks!
