bruceb58
- Joined
- Mar 5, 2006
- 30,611
Re: 4.3L 4bbl hard cold start issue
Really no need to add a timed relay if you have that connection in place. Will take less than a couple seconds of cranking to fill the carb bowl. Very possible that a previous owner replaced a starter without the correct number of terminals on the starter solenoid. I would be checking that before adding a relay.
Are you ignoring the wire that goes to the fuel pump from the starter? That is what I am referring to.No so on Mercruiser 4.3LH and LX carbureted engines. They have one +12V wire supplied from the ignition switch that goes to one side of the oil pressure cut off switch and there is one wire from the other side of the oil pressure switch that goes to the fuel pump. Refer to items 7 & 8 in the ‘B’ block in the wiring diagram on page 4E-4 of Mercruiser Service Manual #18 or page 4E-8 of Mercruiser Service Manual #25.
