I'm hoping this is fairly simple. 22 year old 4.3L always reliable, but sat last 2 years (no stabil) due to illness. Today: initially wouldn't start except on starter fluid or carb cleaner. I topped-off a new fuel filter 3X, the engine starts & runs for about 6 minutes each time, then starves for fuel & dies. When I spin the fuel filter off, the fuel level is down an inch or so, so it's running on fuel from the filter, but fuel is not replenishing the fuel filter. My fuel tank is half-full, I trust the gauge, the needle wiggles around as we move around in the boat cleaning, like the gas is sloshing a bit in the tank. The pump is between the filter & the carb, so fuel is definitely going through the pump to the carb. How do I know if the pump is pumping? Is there a simple troubleshooting method to confirm the pump is running? There are no fuses involved anywhere, correct? Thanks in advance.
