4.3l bogs out on WOT
CaptDuck
Long time lurker, first time poster here!
I have a 2003 Mercruiser 4.3l in a Bayliner 1850 open bow. Engine serial number is OM375871 and it is a 2bl MercCarb. It has about 200 hours if that.
This past weekend i decide to take if out for the first time since last year. I gave it a once over before we left. Hooked up the muffs and she started right up. Oil looked good and everything appeared to be good to go. I get to the lake and she fires right up. I put along to get away from the no wake zone and then decided to opem it up. Well no go, she just bogs down flat on her face.
From what i have been reading on here it could be the oil pressure switch. I did the jumper thing and it started up and is spitting out fuel. I reconnected the wire plug to switch and she still runs. I am going to go ahead and buy a new switch. I pulled the water/fuel seperator filter and it was gunked up. I replaced it. Drained all the fuel and put in fresh fuel. I know the pump is working as i disconnected fuel line to carb and plenty of fuel comes out of fuel line. I will pull carb and clean it up just to be on the safe side.
Anything else i should check? How about the ignition coil?
Thanks in adavance.
CaptDuck
Re: 4.3l bogs out on WOT
I tried to work on it somemore this afternoon. I noticed no fuel was coming out but i could hear the pump working. I disconnected the fuel line from tank to water/fuel filter and i could barely get any suction. I connected fuel line from tank to pump and she pumps out plenty of fuel. I pulled the filter off and it is full of fuel. But it is just not getting up to the carb. I wonder if the base of the water/fuel seperator is clogged up. Could that be possible? Or could it mean pump is getting weak?
JJJ
I'd try cleaning the fuel separator first and see what happens, could even be a plugged filter again if there is that much junk in the tank.
CaptDuck
The tank is clean. I took out all the old gas and cleaned the tank. The put fresh gas in it. I did discover another fuel issue. When i took the water/fuel seperator filter and housing off. I noticed the fuel line going from filter base to the fuel pump was stripping out on both ends. Not make a good tight seal. So that may be why the pump is not getting fuel from filter. It is leak air into the system. I making a new stainless steel line and new fitting with flared fittings on both ends. Hopefully that will solve that problem.
CaptDuck
Well it appears that my problem has been solved. I made new fuel line out os stainless tube and recoonected fuel pump amd filter. Turn the key and she had plenty of fuel flow now. I will verify it on Sunday when we head to the lake. Now on to my Tach not working.
Ayuh,..... It don't take much of a vacuum leak to shut down the fuel system,...
good luck,... I think yer probably in good shape now,... if anything, check, 'n change the filter again in a few hours run time...
CaptDuck
Yeah i noticed that. But glad i hopefully found the problem. I ran it fro a little while on muffs and she was purring like a kitten. I will change out filter again half way thru the season. I don't use it all that much. As i usually out on my 100' commercial fishing boat more than on my pleasure boat! Something wrong with that!!!!!!
CaptDuck
UPDATE.....Well my problems wasn't solved after all that. I took it out again today. It ran a little better than before. But after about 10 minutes it started doing the same thing. so i broke out the jumper wire for the oil pressure switch. Put it in place started her up and she ran like a scalded dog. So i have ordered a new oil pressure switch. And that should take care of my problems. I put the wires back in place to verify and she did the same thing. So i think am safe to say that it is the oil pressure switch.
