My new engine (4.3L - Carb) lacks provision for a mechanical fuel pump so an electric one is required. A Carter P61122 as used on '92 - '94 Mercruiser/OMC/VP carb/TBI engines and should be ideal for my requirement.
However, the needed fittings are not readily available. I believe the pump inlet is a 9/16 - 18 female connector. The threads are straight - NOT tapered so pipe fittings are out. The outlet is similar but 3/8 - 24 size. There is no inverted flare surface etc. so sealing will have to be via 'O' ring or copper washer at the end.
I was given the following mercury marine part numbers without further description or any dimensions.
fitting 1 with oring: 8058027A1
Grommet: 13467
Grommet 2: (other end) 817491
fitting 2 with o-ring: 805026A1
Can anyone provide additional info on these parts or recommend others that will work?
Thanks.
Grommet: 13467
Thanks.
