4.3l gas issue
eastont
I have a Carver with twin 4.3 Mercruisers and my port engine uses more gas than the starboard one.
Last year I switched carbs and that made them a little closer, but I don't now if it meant that the starboard was using more than it was previous. I also had a valve job done on the port engine and that mad no difference.
So based on this bit of information, does anybody have an idea as to where else to look. I am handcuffed to the marina because of a contract clause in my docking agreement.
And I don't think the mechanic at the marina is incompetent, just seems to be scratching his head.
Re: 4.3l gas issue
Ayuh,... A Compression test is a pretty good indicator of the motors general overall health...
90stingray
Re: 4.3l gas issue
How do you know one engine is using more fuel than the other? Are you using fuel flow meters? Have you thought to swap the transmitters?
eastont
Re: 4.3l gas issue
I have separate gas tanks for each engine. No I don't have flow meters. And according to the mechanic's test before the valve job, all cylinders had good compression but for the one that had a bad intake valve.
