4.3l merc engine troubleshoot
kbmeds
OK guys got a few Q's for the mech's around here as I am no boat mech but I am a huge DIY type guy..so here's the run down
Milky oil- changed oil out three times each time the oil got lighter and lighter so I belive its working.its way out.. boat was flooded and almost sank and was hydro locked had 5 gallons of milk in it..
New starter, plugs, oil, oil filter basic clean up on motor and purged the motor of water/milk and she fired right up..check cooling system and water flows just fine thru it it seems to come out the port side exit.more than the star and the star also has exhaust coming from the cooler exhaust...also a bit of milky oil came from prop along with a huge cloud of white smoke upon first start up(burning off oil in combustion chamber)
Ran fine on muffs...took it to the lake to get a lap in and get a feel for what's wrong..as soon as I went to start in in the lake it was hydro locked again..pulled plugs at dock purged motor (about a cup of water) put plugs in and fired her up(water could have got in from me testing cooler?)
we trolled for few and then went to give it gas and she bogged almost to stall I let off the gas and she ran fine..slowly got rpms up to.about.2000 and we did a few small circles staying.close to dock she ran fine.so I decided.to head out to open water and POP!!! backfired and stalled out..I tried turning it over and wouldn't start.. I pulled all plugs again and one had a small amount of milky oil in it purged the motor and nothing.came out this time gave it a few minutes threw the plugs in and started it up this time having to give it a good amount of gas to get it going ..she got.up to about 1500rpm on the way back to dock and was running OK till on the trailer
got a set of head gaskets and will be tearing it down today anything I should check?
Struc
Re: 4.3l merc engine troubleshoot
Check the exhaust manifolds. The procedure is around here, but basically fill them with acetone and see if it leaks to the other chamber. The engine and / or heads could also be cracked. Check the lifter galley for cracks as well as below where the heads bolt on. Often it's hard to see with the motor in the boat.
EDIT: If you end up needing to replace the motor, check out my thread:
http://forums.iboats.com/showthread.php?t=520824
