b18apwr
- Joined
- Apr 6, 2009
- 22
I know this topic has been beaten to death, but I just want to get a little clarification from the experts. I have a 2001 Mercruiser 4.3L, 2bbl Mercarb, Alpha 1 Gen 2. I, like many others, experience run on. In my case, I don't have to run the boat very hard at all to experience this. My timing is right, I'm running 93 octane, just performed a full tune up (see below), but normal running for just a few minutes - and not near WOT or under load - results in a run on / dieseling of my engine. I put my boat in the water for the first time this season over this past weekend. I was hoping my full tune up would have solved the issue, but it didn't.
My question is about the idle speed. At times, when I return my throttle to neutral after running, my idle seems to be higher. I did notice that it looked like the linkage wasn't always returning to rest against the idle cam. I've turned the barrel on the throttle cable a few more turns to add some extra pressure to hopefully rectify this. I haven't had the opportunity to see if this works. Now, back to the question about idle speed. I've seen accounts where the boat should be in gear on the water and the idle should be set as low as possible to keep the boat from stalling. However, the manual never mentions setting it in gear. I have a shop tach and have set my idle to 650 in neutral in the water. Was this wrong? Should I have done this in gear instead?
I bought the boat last fall and only got to take it out twice. Over the winter lay up, I replaced the plugs, cap, rotor, fuel filter, impeller, drive oil, and engine oil. The timing is dead on and the boat operates at an indicated 150-160 degress dead on. Any suggestions on how else I can beat this run on / dieseling issue?
