Is there really a difference between the ac delco MR43T that the boat calls for and a regular R43T plug? I have also been having problems with the engine wanting to stall when I give it gas. It idles fine. It has sat since last year because of a bad fuel pump wire I never replaced until now. When I first fired it up it ran OK as long as the jumper cables from my truck were hooked up to it. As soon as I pulled them off it started to act sluggish. The plugs are black, and have a minor smell off gas but are not wet at all. By the way the motor is in a 1992 19foot Seaswirl. The motor is a 4.3L OMC (GMC) Thanks for any advice you can give me.<br />What should the timing be set at?
