farmer9009
Thread starter- Joined
- Aug 23, 2009
- 69
I have a 89 merc 4.3L with an OC serial number. it has the thunderbolt IV ingnition system. The problem is that it will run great at WOT for about a mile then it starts to surge and pop through the carb. So today i checked the timing and set it to 8deg BTDC. Also set the mixture per the manual. aditionaly I changed out the sensor in the distributor. New fuel and the filters were clean today. Cap rotor wires and plugs are all new. Timing stays at 8dg when at idle but only advavces to around 18 BTDC when WOT. looking for sugestions.
