bruceb58
Honorary Supreme Mariner
- Joined
- Mar 5, 2006
- 30,834
The output of the relay that is not the fuel pump relay goes straight to the coil. There are two connectors at the coil. On set of wires goes to the distributor and the other on has a purple and gray. You need to be measuring 12V on that purple wire.
Just so you know, it is likely the color of the wire leaving the relay changes color to purple on the way to the coil.
