Lt1z350
- Joined
- Feb 25, 2022
- 79
I found some posts on this but no one says I gained x from the swap. Some are 2bb to 4bb so those don’t work.
I got a 94 4.3lx non vortec heads. I see edelbrock has an intake and they claim 18 hp vrs the stock merc cast iron. I have not taken off the carb but stock looks to be open plenum single plane which has been proven to be terrible from idle to 4500 rpm vrs any kind of dual plane intake and that’s the range on this motor. So that alone says the Edelbrock should be much better in the 4.3 rpm range.
What I was hoping to find was someone that did it and posted I was 43 mph with stock and now 48 mph with new intake. More air probably will lean it out there seem to run a little rich stock on this 4 bbl stock carb. I might do the 1409 at same time which I did find guys that posted what jets and rods worked best. Unfortunately no way to put a wideband sensor and tune it perfect as I have a stand alone setup for tuning cars. So tuning your plugs and peak mph will net the most hp.
I just re proped the boat to a 4 blade 19p and hole shot is excellent now but wot is 4300 rpm and 44 mph and I’m trying to eek 50 from it if possible then cruise at 35 should be a little more efficient. Plus have that flat out speed if I want it.
I do not want to do heads as I’m going to v8 swap it down the road so intake and crab gains maybe rocker arms as I have them depending on if I feel like taking the exhaust off to gain 8-10 hp from it. I guess this motor is 180 hp some say the crate engine is 225 now maybe different cam I know the later better heads but seen 190 hp on that model so many hp numbers on a lot of the same parts so wondering how much of that is also in engine timing.
But anyone that did the swap and can tell me exactly the gains is much appreciated.
Thanks
Thanks
