Re: 4.3LX Mercruiser Carburetor
That's an Awlfully Tall Title to Step Into bluewater19......
<br /><br />Dump,<br />Ya, What he said......<br />You'll Gain a Solid 20hp from Each motor....<br />The Swap is a Really Easy one...... <br />The Most Inexpensive way is to Find a Merc. Take-off, Used..... <br />New, Aftermarket, would be around $500. or so....<br />IF Your motors are 1991s,<br />You'll need the Manifold with Six(6) bolts on each side for a Total of Twelve(12) hold down Bolts........ There is a newer one, the Vortec Style, It has Only eight(8) hold down bolts.....<br />And, Yes, I Love the Merc/Weber/Carter/Edlebrock Carb... Easy to Tune... Easy to Service....<br />Economy ???.....<br />A 4bbl runs on Only the front 2bbls when you're Idling, on Up to around 3500rpms(when the Secondaries come in).......<br />If you Prop the boat to Run 4600rpms at WOT.......<br />Then Cruise at about 3000/3200rpms......<br />You Should be able to pull in a Good gph......<br /><br />I've got Mine Running Clean, but not Lean.....<br />And I have to pump gas
Out of the tanks, Every weekend....
