Hello,
I'm having an issue with my SeaRay 200BR and 1991 4.3LX. I re-propped with a 14.25x19 4-blade SS and I'm only getting 3600 RPM WOT when loaded and 3850 RPM when running solo. It seems like that prop should be OK from what I've read on this site, so now I'm wondering about the engine setup.
A new carb was installed prior to my purchase of the boat used. It is an Edelbrock 1409. The engine does bog briefly when the secondaries open, but seems to run great when on 2 barrels. After the bog, it seems to run ok on 4 barrels, but with no significant performance increase. The secondaries are set to open late - with the last 1/8 throttle travel.
Should I be able to turn this prop around 4400?
