4 bbl on a 4cyl?
Rob454
Re: 4 bbl on a 4cyl?
I dont know but even if they do the smallest 4 bbl will be BIG for a 4 banger
Rob
PowerAddict
I know pontiac put 4bbl package on their 4cyl in the 60's so it could be done so I just figured I'd ask.
Don S
Boat ------- Car
Two completely diffent engine setups, what works for one, won't work on the other............ as well.
Flukinicehole
My brother has the 190hp 4cyl 4barrel I dont like the engine but they made them. It`s got a 460 ford head on it.
WillyBWright
There are adapter plates at automotive supply stores where you can mount a 2-barrel carb on a 4-barrel manifold. The one I saw looked like it could be used upside-down (with a spacer to allow room for the butterflies). You'd want to max-out the opening to allow additional flow. If you take the manifold off to do that, match the passage edges to a brand new gasket and scribe a line inside the intake ports. Then chamfer the manifold and head intake passages to allow for max flow. ;)
I'm not aware of any stock or aftermarket 4-barrel manifolds for the 120/140 GM. The 190 is a 4-barrel 170 which is mostly Ford-based.
PowerAddict
i would consider that, but since the intake runners on that manifold are set up for 2 barrel, I'd be worried it might do more harm than good.
however, gasket matching the intake might not be so bad anyway.
Bob_VT
Yes the 470 mercruiser was marketed as a 170 hp equipped with the 2 barrel and 190 hp with a 4 barrel.
Putting a 4 barrel on that old engine would be a waste of cash. Keeping it in tune, make sure there is no excess junk in the boat, check to see if the flotation is water logged and be happy. The closest alternative is to look for a faster boat.
180shabah
I agree, what are you hoping to get out of the upgrade, 10-12hp and an extra 1/2 MPH on the top end??? It will not plane any faster, that takes cubes.
Limited-Time
Bob hit the nail on the head there.
