Re: 4 bl carb and intake for 4.3 OMC
Guys,<br /><br />Not so fast with the pronouncements.<br /><br />I have the same 1987 OMC 4.3 2-bbl. Now, normally, with car engines, putting a bigger carb on a stock engine is waste of gas and money. That's because the compression, valves, cam, exhaust, etc., also need upgrading to gain significant hp.<br /><br />However, I just looked at my OMC 4.3 parts manual.<br />Hmmmm.....the ONLY difference between the two versions is the manifold and carb. <br /><br />OK - that tells me that you gain 20 hp and 200 rpm by just changing those two parts. <br /><br />Based on these facts, his upgrade notion might make some sense....
