4" Heat Exchanger U- Bolts
yamhoss86
Does any one know where i can purchase the U bolts for the 4" heat exchanger?
Any other alternatives to the U bolts?
Thanks
Bt Doctur
Re: 4" Heat Exchanger U- Bolts
a good hardware store, electrical supply store, trailer supply
HT32BSX115
Thanks
Howdy,
Mine is held on with stainless steel hose clamps.
If you reveal what you're working on, and maybe include a picture or 2, we could be of a little more help.......
Regards,
Rick
Live-liner
Hi,
I just did a R&R on mine and ended up re working the threads so I could re-use them. I thought about using ss hose clamps but managed to salvage the u-bolts. I am very confident that the hose clamps would work fine. I would also suggest putting a rubber pad between the mount and the exchanger. I use a 4" furnco cut in half.
Good luck!
I have several pieces of heavy equipment and 4-inch exhaust is the norm. Check with NAPA or other heavy equipment manufactures, peterbuilt, cat, kenworth, etc
