Don Hansen
Thread starter- Joined
- Sep 17, 2007
- 230
I have a 1970 4hp Lightwin that started to act up while on a fishing trip. Here are the symtoms. Most of the time when pulling the rope it hardly tries to run. Sometimes it will run for just a few seconds, sometimes 10 to 20 seconds or longer. Three or four times it ran fine for more than 10 minutes. Then it starts to slow down, still running smooth, just like the throttle is being turned back until it stops. Keeping pressure on the primer bulb does not help. Taking out the high speed adjustment screw shows the carb is getting plenty of gas. The plugs show signs of gas but it's not flooded. It's pumping plenty of water, although I did find out on this site that there still may be a blockage. Someone pointed out that it seems to make a squeaking sound as it's slowing down but no binding is felt, or squeak heard, when pulling the rope. It has lots of spark, flywheel has been off twice and no problem found except the plate that holds the points has a bit of side to side play. Not sure if that's normal. The carb has been taken apart three times, cleaned it with carb cleaner, and no problem found. After returning from the trip, and the motor having sat for a week, I took a compression check with the motor cold. I got 90 lbs upper and 80 lbs lower. After squirting in some fogging oil I got 130 and 125 lbs. With the carb off, holding my thumb over the intake I seem to feel nothing. Not sure if that's normal.
Don Hansen
Don Hansen
