4 Hp Nissan not starting after running out of gas
Shane0524
i ran my 4 hp nissan/tohatsu 4 stroke out of gas (i had more ,i use the internal tank)so i refilled it with gas and it would not restart i had to row the boat a half mile to my dock and then it took a half of an hour of blasting starting fluid into the carb and pulling it through for it to finally get started and get the fuel pump primed. i pulled the fuel line that comes out of the fuel pump off and it was totally dry. so it took the fuel pump off and took it to my dealer he opened it up and said it was fine. so i put it back on and it ran fine. i ran out of gas again and was worried it would not restart but it fired back up with no problem. then i ran out again and i took a lot more starting fluid to get it going again. someone told me that you are no supposed to run these engine out of gas for the reason that they are hard to restart but i have been running it out of gas like this for years and it always fires right back up after a refill with maybe a bit of throttle and a few pulls. i am wondering if this is abnormal or if i have been lucky with getting it to restart for the last few years that i have owned the motor also i don't get how it could do it one time then not do it then do it again......maybe different throttle settings??..?....
pvanv
Re: 4 Hp Nissan not starting after running out of gas
You need to ensure the fuel tank is full to help prime the pump, and the filter needs to be very clear. Also, the fuel pump suction may ne a little weak. You can test it with a fuel system pressure/vacuum gauge, if you have an olde-tyme mechanic who has one (or Tohatsu still sells them).
Normally, we just shut off the fuel **** to run the carb out... and dump the gas at the end of the season so it doesn't spoil.
Shane0524
my dealer said hat the pump was fine:)
TOHATSU GURU
It's more like a dirty carb at this point. Chances are you have a piece of trash floating around in there that gets sucked in to one of the jets when it runs out of gas. It's a random annoyance. Have the carb cleaned and it should go away....Keep running the engine dry.
