jimmythefed
Thread starter- Joined
- Oct 17, 2004
- 10
I've had two stroke motors in the past (Evinrudes, Johnsons and Mercs), however, I just purchased a 2000 Honda 4-stroke. Unfortunately, the guy I bought the boat from does not have the manual. I assume winterizing procedures are the same as the 2 strokes... that is, changing the gear oil, adding stabilizer to the fuel tank, pulling the plugs and fogging the cylinders, etc. I also assume that I'll change the crankcase oil as well. I have a couple of questions: I've read at various sites that it's absolutely imperative to drain the carbs, as these Hondas have extremely small jets and they tend to gum up after a couple of months' storage. Is this necessary if I run stabilized gas through them for awhile? I've always heard that it's better to store them "wet". If I need to drain the bowls, is there a drain or do I have to remove them? Also, is the lower gearcase oil the same type as I've used through the years? Finally, what type of oil should be used when I change the oil in the crankcase? Is it OK to use a standard 5W-30? Or do I need a synthetic, or a type with special additives for a marine environment. This is my first experience with a four stroke and a Honda, and I don't want to go blindly into this. Oh yeah, one more thing, I assume that after I flush with fresh water (do I use muffs, or is there a flushing port I can hook a hose up to?), setting the tilt all the way down will suffice to drain any water from the cooling system. Thanks to any 4 stroke Honda owners or gurus out there who can help me out! <br />jshultz@comcast.net
