basstender10.6
Thread starter- Joined
- May 15, 2011
- 131
My 1999 evinrude 5hp 4 stroke runs great but after running for a while at high rmps, it will loose power begin to smoke and puke oil down the leg from the midsection. I have been told that it is most likely the engine "making oil" and when the level gets too high it pukes the excess oil into the intake through the crankcase vent hose, which causes smoking and what doesn't get sucked in goes into the lower pan, then drains all over the leg. Could this be the problem? If so, apparently I have to change the oil more often and make sure to keep it on the lower side. Or could something else be wrong?
Thanks for the help in advance.
