Having run "Amalie, Better than it Has to Be"....automotive non-detergent motor oil.....to 6 gallons of gas because as the story goes OMC had some brass bushings in their engines and we didn't have 2 stroke oil available back then, and rather than needle bearings for the wrist pins and all, they used bushings that needed lots of lube any way....the reason for the 24:1 as I saw it.
Many 10's of years later, after having joined this forum and learning about Sea Foam (engine additive) and the "decarb" process, I don't put any more oil in my engine than is called for, with the exception of my last engine that had a variable ratio oil pump onboard and it ran 80:1 at idle up to 50:1 at WOT. So when I disabled it (10 year old engine and didn't want to trust it any more) and went to pre-mix like I had done all my life anyway, I had 50:1 at all engine speeds.
I agree with jimmbo!
Mark
