I have an electric start, 40hp 1967 Johnson Super Sea Horse, serial #J2738334, model RDS-29E. I am replacing the shift mechanism form the shift handle to the engine because of 'slop' resulting in the need for a greater throw than my control box and cables will handle.
I have removed everything into what is shown as part # 307451-"bearing , sleeve". (In the lower unit group)
Question is: How do you remove that bearing, sleeve?. I tried pulling it out with a moderate amount of pull, but don't want to force it too much.
The control box is the original Whitney (Buddo) Mark lll. The throw from full forward to full reverse is 2 3/8. The throw needed with the present sloppy shifter is approx. 2 5/8 as best I can measure it.
Any thoughts on the subject beyond my one question will be appreciated.
