Re: 40 HP 1976 Johnson Seahorse Model # 40R76R
Okay newk0001, here is how I installed a Tale Tell stream on my Johson OB. If you look at the very top of your OB you will see two cast bosses just behind the head of the engine where the plugs are installed;
This is my OB just before I disassembled it for a complete rebuild... I know it looks really ratty...PO what can I say?
This is where I installed the 90% brass fitting;
This is the same engine disassembled and sandblasted before any new parts go in...
I used a 90% 1/8" NPT brass fitting because I'm not sure there is enough area between the top of the block and the cowling to fit a straight fitting and the tube and loop from the tube. I bought the fitting on EBay and the 1/8" NPT tap also. Neither were very expensive...just a few dollars.
I used a 1/8" drill bit to drill through the existing threaded cast boss area. Seems they cast those two threaded bosses there for some reason but for what I just don't know. But as you drill down with the drill bit use some grease around the drill bit so as the filings are cut they get stuck to the grease instead of going into the hole. Don't worry if you get a few in there because this areas is nowhere near the impellor pump and would probably just wash out when it starts up... But drill slowly becasue just under this area is the water jacket for the top cylinder;
I don't know if you can see the top cylinder in this picture but that is all the room between the top of the block and the top cylinder (about a ?” or so), so just drill easy. Once you drill through, drill the same hole for the actual tap and tap it for a few good threads. The NPT tap is a tapered tap so use the appropriate drill (I think it is listed on the tap) and again tap slowly and use the grease again. Once you are satisfied you have tapped it far enough fit the brass fitting and adjust to your liking... Nothing really to it. As for the output hole in the lower cowling section, just pick a place toward the starboard rear section of the lower cowling plate and put a fitting there to receive the hose you installed on the brass fitting you just fitted... Now when you start up your OB there will be a constant Tale Tell stream flow letting you know for certain your water pump is working... I sure hope this is helpful and understandable...
