40 hp excessive gas use
fourbox43
I used to have a 1975 75 hp that used way less gas than my 1990 40 I sometimes have power fluxuation but I have a 12 gallon tank and after 20 minutes running all out i done used 3/4 of it but at todays gas prices makes enjoying the water a little hard.
A friend has a 1991 48 hp on a heavier boat and uses on 1/4 tank of gas to my 3/4
any suggestions please help
:confused:
Re: 40 hp excessive gas use
Maybe it is leakiing gas. Take off thecowling and observe the carbs. See if there is leaking gas into the water.
my guess is that your either running really rich, or you have a leak.
fourbox43
i checked for the gas leak no leak the problem didnt start until i gave it a tune up. but went out today it dont want to start and it is leaking oil mixture through the prop
if its leaking fuel and oil mix thru the prop, either you are not running on all cylinders or your running way too rich. fuel that is supposed to be burnt is making to the exhaust thru your prop.
fourbox43
air filter , plugs, wire and power pack
tx1961whaler
Back to basics: Check the compression and spark on both cylinders. Then use a squirt bottle of premix and squirt it into each of the carbs when it is running to see what the results are.
Did you mean fuel filter?
