40 HP Johnson, just tilt or tilt/trim?
Dragfluid
Scott06
Hi folks. Just picked up a '93 40 HP remote. It has a good sized, single ram mounted to the pump. Putting the model # (VJ40TLETB) in, I got this.
It calls it tilt/trim. The piston IS fairly big. So, is this trim too, with just a single ram?
Not a big deal, it's for a pontoon and being on the river, I need tilt more than anything. Trim would be a bonus.
Thanks in advance!
I would think if they are calling it tilt and trim then yes you can trim with it.
There was a note on the parts page you listed Power Trim/Tilt "F" Model Number Suffix Only
do you have that in your model number?
Dragfluid
The b and f suffix blowups were on the same page when I looked. Mine is b, but they both looked the same as far as I could tell with a quick look.
