40 HP Johnson oil alarm
rbj
The oil alarm on my 1989 40hp johnson o/b motor comes on at idle, is this normal? Just got this boat so we're trying to figure out what's right and what's not.
tashasdaddy
Re: 40 HP Johnson oil alarm
which alarm is it?
J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat and fuel restriction alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
has the motor been sitting a good while? did you try priming the oil system?
personally i would disable the oil side on the VRO2 and premix.
